What number of heads do you have? It's unfortunate that this little boo boo is turning into such a pain.
Can you see the hole in the port? It looks like the hole just goes into the exhaust side of the port. As recommended before, tapping and plugging may work. Another head would also be my choice.http://imgur.com/e0iLdrZl.jpg
That's what I'm working with.
I thought about just going back with the same enlarged stud but puttin JB Weld on the bottom to keep water out
You're right TMM.... exhaust side. Now I'm wondering if JBWeld will hold up all that long with the heat. There are expoxies that will hold up in the heat, espcially if backed up by a setscrew or similar.Can you see the hole in the port. It looks like the hole just goes into the exhaust side of the port. As recommended before, tapping and plugging may work. Another head would also be my choice.
No...time for a pipe plug/set screw threaded in a hair below the rail...then drill/tap for valve cover bolt. Don't forget the red loctite on pipe plug/set screw.Time for another head.
This stuff should hold me until I find another head.
This weekend is Father's Day so I should get about a half day to myself. But knowing the wife that honeydo list will be longer than the Christmas list!
