jglover_81
I am trying to get my 72 Scamp back together and running but unfortunately I am on a fairly tight budget. The 318 that I put in the car when I was 16 has been sitting for about 12-13 years and at some point the carb was removed without me knowing. I have a 360 out of a 73 van and decided if I have to spend the time and money on rings and bearings at the minimum then the 360 will get the time and money. I have tore the 360 down completely and cleaned everything. My question is there is a slight ridge on the cylinders when I measured I came up with approximately .0025 on the ridge. Is that safe to ream the ridge and go until I get the budget for the 408 build or does this block need bored?
