yellow68runner
Banned
what are the benefits if any ? what other mods do you have to do /
yes or you can just put them both on same side of the gauge and tighten the nut!
I'm thinking if you simply connect the two leads from the amp gauge together, you still have the same amount of current flowing through the bulkhead.
If the bulkhead connections are clean, the wires are in good condition, and you are not running higher than stock electrical loads, your amp gauge is just fine...
And if your 30+ year old amp gauge does burn out, your alternator will quit charging, and your battery will go dead.
The mad electrical bypass and adding a voltage gauge is the best solution to the whole situation in my opinion.
