for you guys running caltracs, what is your theory on adjusting them, which hole do you use the upper or lower?
could you use cal tracs with your springs moved in board (under the frame)?
There noisy on the street with the solid front spring eye bushing and contact on top of the spring.
Do Cal-tracs negatively affect handling?
They cant ride and worse then SS springs. If the solid bushing bothers you maybe you need to drive a Cady.
Depends on how much pre-load you dial in. More preload = stiff
If you know your settings for a drag run, you could always dial it back for the street, then wind in the required preload at the track. Might take 5 minutes.
