'68 318
performer intake and 600cfm carb
675 heads
Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/220
Gross Valve Lift (Int/Exh): .454/.475
LSA/ICL: 112/108
cam was installed at factory specified timing, not advanced or retarded
stock exhaust manifolds
Car runs great in the winter, but not in summer.
During the winter, for the last two years;
the car warms up just fine
idles just fine
runs great.
During the summer for those same two years;
Idles for crap, I need to constantly have to cover the gas pedal and watch the tach
runs not so great.
When under load, either the valvetrain is rattling like a can of rocks bouncing down a mountain, or it's detonating, especially going up hill and that's with the 91 fuel we have here.
When I adjust the idle screw on the carb in the summer, it either wants to race at around 1300+ or stall. I can set it just fine in the winter. Timing was good in January.
Things I know I need to do;
new points or the new dizzy sitting next to my keyboard here.
check plugs (haven't checked since replaced last summer, but car was running just fine until about a month or so ago).
compression check
390 or 470 stroker (for those who say to ditch the teener)
After the to do list above, any thoughts or recommendations? Do I need to add anything else to the to-do list to help diagnose this issue and resolve it?
675 heads
LSA/ICL: 112/108
idles just fine
runs great.
runs not so great.
compression check
