grease monkey 73
Hey guys im building a mild318 for my daily driver I have a 74 block that's goin to be bored .30 over stock crank and rods flat top pistons a set of "302" heads I plan on porting n polishing a stock 4bbl intake Im goin to port match to the heads from what I have read a stock 360 hi pro cam would work well with this set up.
1 what do yall think?
2 If yes what are the specs on that cam?
3 What size carb would you recommend?
4 and what kind of horsepower numbers do you think it should make?
