swing69
fightin' socialism
I'm trying to install new cam bearings in a 74 360 short block. Old bearings are out. Trying to get the new ones in.
Sheppard book says, install 1 or 5, work outside to inner bearings. I installed #5 (rear)...then flipped the tool around to install #1 from the back side.
Bearing #1 needs to on the tool when it is between bearing 1 and 2. But I get bearing #1 between the #1 and #2 positions. Crank is in, can't put it up through the bottom. The valley "slot" is too small to get the bearing in from the top.
I think I have 2 options:
1) install # 1 from the outside, but I won't have the "cone" on the tool to align it during install.
2) drive it through the #2 bearing hole, then into the #1 position. I really hate that idea.
Am I missing something? what is the obvious "other" way that I can't see?????? :sign3:
