stroker416 Destroyer of Legend at C/S Speed LLC FABO Gold Member Joined Mar 13, 2006 Messages 337 Reaction score 120 Location Scott Township (Lackawanna County), PA Mar 18, 2024 #1 Is the beveled was for the cam gear on a slant 6 that same as the small block cam washer?
Badvert65 Long Time Mopar Nut Joined Sep 21, 2014 Messages 440 Reaction score 233 Location Brightwood, VA Mar 18, 2024 #2 I am pretty sure it is the same as the big block Mopar engines. I don't recall whether the small blocks used a washer as they have that fuel pump eccentric bolted to the front of the cam (and wouldn't really need a washer.
stroker416 Destroyer of Legend at C/S Speed LLC FABO Gold Member Joined Mar 13, 2006 Messages 337 Reaction score 120 Location Scott Township (Lackawanna County), PA Mar 18, 2024 #3 Yup. I found one on the wrong shelf, competely different from small block.
