That clicking sounds like a low battery to me. Try jump starting the battery.
Next then try crossing the terminals on the starter relay to see if it will turn over.
I doubt that your engine is locked up. I do not hear the starter engaging. If the engine was locked up, you would hear the starter engage and then hang up.
Make sure all electrical connections from the battery, to the starter relay, to the starter are good, clean, and tight.
Then report back.
Then report back.
