Car is back from Paint !!!!
Man that is one sweet looking Notch and I also couldn't bring myself to put a vinyl top on it but its your ride make the way you want it.
Beautiful car. I love the Notchbacks. Do yourself a big favor and Dynamat the inner roof skin. You can get bulk 0paacks at Amazon.com with free shipping. I would also do the firewall starting up as high towards the bottom of the windshield as you can get it, but just down to hour heels and maybe a few spots where your mufflers will be. Then put a few strips on the inner and outer inside door skins just to deaden the resonation.
Once you get that in, line the entire car's interior with "The Insulator" from Aircraft Spruce. It's very reasonably priced and when used with that aluminum tape with the wax paper peel-off liner. You can seal dozens of custom sized pieces together into one big blanket that keeps out road noise, odors and sound better than anything I have ever found.
My car is quieter than a Bentley, while I'm driving down the road. It sounds like you've walked inside an anechoic chamber or a bank vault when you sit in it. It's well worth the effort. and few hundred bucks to do it.
The trick is to use the palm of your hand and pound lightly on all the interior surfaces and only Dynamat the panels that resonate when tapped. The blanket of insulation is what really does all the sound deadening and keeps out fumes and makes the car mush more comfortable to drive. They do allow for a lot of noise through the wheel wells too, so cover those with Dynamat as well. I did have to glue the headliner blankets up, but the rest of the blanket can be pulled out and re-installed in one piece. I do tape all the edges down just out of sight of the edge of the trim, so you can't see it.
You can find rolls of "The insulator" by the foot in 2 foot wide and 4 foot wide rolls at the aircraft supply chain "Aircraft Sruce" here's the link. The aluminum duct tape is available at any hardware store.
It looks like they only have the 4 foot wide sections now, but ask if its available in 2 foot wide sections. I would get the double sided aluminum rather than the single sided, so it is easier to form, stays dry easier and make sure you plug up all your holes and use new seals on your doors etc.
http://www.aircraftspruce.com/catalog/appages/insulator3.php
I used single layers except for from where your feet rest on the floor to the rear where the back seat starts. I did not double up on the transmission tunnel. I went one inch thick there. When you pound your fist on my carpet, you can't even tell it's there.
Remember, Dynamat is not intended to cover the entire interior of your car. It is designed to stop the panels from resonating and having sound pass small amounts of heat pass through it. It's "The Insulator" blanket that does most of the work. I learned how to do this by copying how they insulate small high-end aircraft. The results are amazing!
Absolutely gorgeous color and car, I love the notchback barracudas and hope to one day own one. Keep the pics coming as it goes back together!
The car really looks nice. Kudos to you and your painter. I'd pass on the vinyl top only because of traumatic experiences with them.
As for wood all day???
[ame="https://www.youtube.com/watch?v=bgMNH5kcaSs"]WE GOTTA GET YOU A WOMAN! Todd Rundgren - YouTube[/ame]
Vinyl top is going on. I busted my *** finding the covered up trim holes and re drilling them prior to paint. I'm a vinyl top fan and my car was born with one and the v6x stripes as well so that is how it will end up. I'm not a nut and bolt purist but I love f5 green with black. I had wood all day just cause I had my car back LOL
Finally I'll have a Vinyl Top partner in crime!!!! MUUUAAAHHHAHAHAHAHAAHAHA!!!
Congrats Luke, I need to come by & see it!
~Sae
After comparing the two pictures, I'd have to say the vinyl top looks dang nice! Can't wait to see what the stripes would do.
The car looks awesome with or without the vinyl roof!
Good job!
Love the color, but i'm a sucker for green cars anyway......
Love the way that turned out. Helps make my mind up. I'm definitely putting the black top on my GG1 green 68 GTS
