i don't think anyone really answered your question fully. you're asking why is tilts to one side, and how to fix it...if it is in fact broken.
first off, on some of these cars chrysler added an extra leaf to the rear springs on the driver side to combat driver weight, which can cause a slight tilt to the right as you describe. with aftermarket pro stock springs the car actually tilts the other way to combat large amounts of torque (probably not your case)
this is why some guys order two, right side, pro stock springs as replacements. not everyone is a drag racer!
anyways first see if your tilt is really excessive or not. find a level cement surface to park on. measure with a common reference from the ground up, maybe to the bottom of the bumper. an inch or so? just drive it unless it's really driving you nuts.
several inches? or you REALLY want it level. you need to make sure the K member that holds the torsion bar keyways in the rear is rust free, and isn't letting your torsion bar slowly twist in the housing, thus lowering the car.if all looks ok, then you're not bottomed out, and BANGING off the bump stop, and can get the car to bounce on that side. then it's probably several lifetime alignments where they never reset ride height and geometry says, you kick the bottom of the tire out to alight it...the car sits lower.
Now how to correct it...
there is a bolt, dead center of your lower control arm. use the same measurement method as above to see how much higher you want the one side to go. fire up the impact and give the bolt a spin. i cant remember which way, but a few seconds and another measure will tell you if you're going up or down. level the car with this method, get it aligned because you just threw off the geometry of the front end. enjoy your now level car...that probably rolled off the assembly line with a slant lol
