CudaGirl1
Active Member
Correct for Dart, Barracuda, Challenger, and Valiant
Date Code appears to be CO
Still has the blue build tag.
No stripped screws or frozen adjustment screws. Air idle screws turn freely. Accelerator pump jet screws turn easily as do the main jet screws. Did not try the main or secondary jets but assume they are not frozen either.
Does not have the electric idle solenoid and am pretty sure the choke pull-off leaks.
Includes a Mopar kit as seen in the picture below. This may be a used kit. The top gasket is absolutely used and has a break at the air cleaner stud. May work for a "try-out".
Throttle shaft has some play on the passenger side primary shaft.
Disassembled to show a no surprises carburetor.
Asking $120 shipped. Paypal or Postal Money Order please. Located in Indianapolis, IN
Thanks for looking!
Jeanne
SOLD
Thanks for looking!
Jeanne
SOLD
