moparspares
First one I have ever put together with info from Larry Shephards book and the Eaton owners manual booklet I got with the Locker.
What is the backlash set at?
I just went out and set my dial guage up again and rececked it and got .012. I was sure I had it .008.
Looks High probably has to do with the legalization of marijuana.
To the rest of us it means that the pattern is to the outside of the tooth which in a sense means it is high on the tooth.
I Tightened the backlash up a bit as recomended and it does now sit a little in from the outside of the tooth. Looks pretty similar to the Ideal Contact (pic).
