[FOR SALE] chevy 350
teringer
kenly nc
Rating - 0%
0   0   0
well I'm moving to nc from md and need to clear out my garage so first is a 350 vortech engine ,uses in a dirt car the engine has 4bolt block std bore, steel crank, aftermarket cast heads with both intake bolt patterns, corvette baffled oilpan ,also 16lb manual flywheel need 500$ was running good when pulled should just need std rebuild THAHKS FOR LOOKING
