68 HEMI GTS
Good news is slant six’s don’t seem to have a cam eating problem…![:lol: :lol: :lol:](/mopar/styles/default/xenforo/smilies/smiley-face-laughing.gif)
And some EDM lifter, just like yr camsavers example, will fit and work in a slant 6. The fact that there isn’t pressurized oil to the lifter changes the actual lifter in no way.
I never said I would.Post #23. Why would you buy, & pay extra, for cam saver lifters for a slant 6, where the cam saver function won't work?
It does, you're correct. My bad.Guys, kindly take your squabble elsewhere, it detracts from the post.
Stupid question - what does EDM stand for?
Except a wire EDM can only cut shapes out of metal, like a jigsaw. These little holes are put in by a "die sinking" EDM machine with a carbon electrode that slowly burns thru the metal. The holes could/might also be put in by laser.electro-discharge machining (eg. a lifter) ...It uses a tiny wire to burn a passage in conductive metal at the base of the lifter face into the oil galley giving a pressure feed to the face of the lifter so its not just a splash or oil vapor fed. There is no debris in EDM to clean out. Most good rollers are pressure fed in same way, a direct jet onto the roller/cam lobe
I promise you he's WRONG.Cookie Truck.
According to cam grinder & SpeedTalk. com forum owner Mike Jones, there is only one FT lifter company making lifters in the USA....& they are very expensive.
If you go to the ST forum, look for the FT lifter thread dated June 29, 2022, it is a few pages long; maybe you can paste it in here so others can read, I do not know how to do it.
