Earlier this week I figured out it was leaking from 2 rust pinholes in the low spot in front of the fresh air hole. I put a piece of clear 1/4" tubing on the end of a roofing caulk tube and worked it in through the cowl drain. Got it in the bottom corner past the leak and layed a heavy bead of caulk in the bottom front corner.. Then took another piece of the tube and carefully turned it to spread the caulk. Next day I caulked up underneath it as well. Thursday I pulled the right wiper pivot and added a zerk and greased it. After which I flooded the windshield and cowl and did not see any leaks.
Started wrapping things up for winter. Hung the fenders back on it today. Need to put stuff away and organize the garage. ( Not heated, and not happening ) so very limited work now that its chillin.
