clip number - body sealers?
swing69
fightin' socialism
Central Socialist NJ
Looking for:
65 Barracuda Sill trim mounting clips.
65 Barracuda rear qtr. top trim clips.
Not having much luck with finding part numbers....anyone know?
Also:
What is the replacement for the OEM seam sealer that they use in the rain gutters and along the trunk area where body seams meet?
Is 3m Auto body sealant the right stuff to use?
'65 Cuda rocker molding clips....part# RS-80S, set of 20 clips and plugs, $84.95.....If using this clip for the A-body 1965 Rocker panel mldg - the clip is for a different vehicle but can be made to work with a little light sanding on either end before they test fit to rocker mldg.....they must be slightly alterered first in order to make work for the A-body
'65 Cuda rear quarter peak molding clips, part# GZ-88148, $1.55 each
