iw378
Here's what I have, 70 318 putting a 4 speed on it. I have a mcleod billet flywheel
and a mcleod street pro clutch and pressuer plate. All going in a 67 valiant. Anyways I installed the flywheel clutch and pressure plate. stabbed the transmission on. All went smooth.
I am assembling on a k frame stand. The to bearing has less than an eight of inch of play between the pressure plate fingers and the clutch fork is almost all the way forward in the hole in the bellhousing. No room for the boot without making the to bearing contact the fingers.
I have a 3517534 bellhousing. I think I have the wrong pivot. do any of you guys have the dimensions for the right one. Here is the pivot I have.
