Clutch fork return spring.
jawbone
Cuda_queer
Richardson, TX
Have a cast iron bellhousing in a 68 Barracuda and no place to secure clutch fork spring. Is there a bracket I am unaware of? I know how you guys like pics.
The spring could be attached to the casting tab ear on the block or starter if you drill a small hole for the end of it. It's mainly to keep the T.O.B. from riding on the pressure plate when the clutch is engaged.
