famous bob
mopar misfit
You guys that are, or have run a coil over front ends ; if I go to 250# springs on the front , I`ll have to adjust the lower spring threaded nuts up higher to get the same ride height correct ?/
I have gone down to 350 # springs from 500 # springs that came w/ my front end.
I have "no" front end lift at all, and am thinking it`s still too stiff, altho it rides a little better that before.
I have the darn nuts ran up about 2 1/2" now , the springs are only 10" springs to start with ! No room with my set up to go to a 12'' shock and spring either !
440/505 727, 3;73 GEARED DANA 60 , 3270 POUND , 68 BARRACUDA, MASSIVE TRACTION PROBLEMS , W/ 10"X 29" STICKY TIRES .
ALL OPINIONS ARE WELCOME , GOOD OR BAD !!-------Thanks, Bob
