gold swinger
Member
I have a a833 overdrive in a dart swinger I believe it is a 1975 but the date code is unreadable. The casting number is c13546 b. I have been looking at replacing instead of rebuilding the transmission is basically toast .It is still in the car.I have found another in great shape. Date code is 1977 casting number is c13303g.Are these the same ?Both are aluminum case and measure the same. Doing a rough visual everything looks the same.help
