69_340_GTS
Don't mill the intake. That makes it special, and it won't exactly "fit" anything else. Instead, mill the intake side of the heads when you mill the combustion chamber side. With a LA engine you take 95% off the intake side vs the combustion chamber. Examples: Take .010 off the CC side, take .0095 off the intake side. Take .020 off the CC side, take .019 off the intake side.OK well. Being I'm looking at $700 to have my heads done up before milling and i will need to have my intake milled more $$. Then I will need to replace my pistons and rings. More money. After all the input from everyone i believe the closed chamber aluminum heads are the most efficient way to get 10:1. I did want to use the X heads but i really don't want to carve them up either.
