I'm looking for some 17" wheels for my car, a 71 plymouth scamp. Most of the wheels I'm finding are in mm. My rear now is a 14x70x245 and my fronts are 17x70x225. What offset do I need for my rear and front for 17" wheels.
I would highly suggest you get under there and measure, measure, measure. 1972, my back rims are 15x8 4.75 back space. It centers the tire perfectly. I'm exactly half an inch from the unmoved spring and unrolled fender. But before I picked those rims and tires. I got under there and measured. First make sure the car is level. Then run a plumbob from the two contact points. The spring and the inner fender lip. Measure between the two. Subtract 1 inch (1/2" per side for movement while driving). This is your max section width on a centered wheel. Now measure from the front plumb bob to the wheel mounting surface. Then from the back plumb bob to the wheel mounting surface. This will tell you what back spacing to get. Don't just "assume" that what fit others will fit yours. For all you know that rear is not original and wasn't centered right when it was put in. Or maybe the springs were moved. Or who knows what else. Make sense?
We need to know more bout your car.
Have you converted to LBP or are you still stock SBP?
If LBP how was this done as it will effect your offset front and rear.
Does not matter if the wheels are 14", 15", or 17", because wheel diameter has no bearing on backspacing at all.
I think where you'll see the metric dimensions is for "offset". A 7" wheel with 4.50" backspacing has 1" of positive offset or around +25mm. An 8" wheel with 5.00" backspacing also has 1" or +25mm offset.
This is not accurate whatsoever. On a 14" or 15" wheel you can't run more than about 4.75" of backspacing in the front because of contact with the UCA, regardless of width. That basically limits you to a 7" rim in the front. Yes, if you work it out just right you can use a 15x8", but there isn't much point because you can't run a tire wide enough to matter. You're basically stuck with a 235, and that will fit on a 7" wide rim.
If you step up to a 17" rim, you can run as much as about 5.6" of backspace, the rim clears the UCA (with a low profile zerk on the upper ball joint). Most rims start to interfere with the outer tie rod around 5.6" or 5.7" of backspace. Some can run a little more, but not most. 5.6" of backspace lets you run an 8" wide rim with ease, and you can run 245/45/17's or even 255/45/17's without issue or interference.
If you go to an 18" rim, you clear the outer tie rod. An 8" rim can have as much as 6.3" of backspace. A 9" rim will now fit up front, usually with the best fit around 6" to 6.2" of backspace. You do have to watch the UCA as full lock with that wide of a rim, tubular UCA's come in handy to run an 18x9 or 18x9.5. But now you can run 275/35/18's in the front, like I do on my Duster.
For the OP, do you know the part # of the wilwood kit? There's more than one, and the offset added by the brakes is different with different kits. What kind of tire width are you looking for? Backspace requirements change with the width of the wheel. Do you want to keep a 225 wide tire up front and a 245 out back and just go to a 17" rim? You could run 245's all the way around pretty easily, although that's probably about as wide a tire as you can fit in the back with the stock spring locations.
Its the 140-11023 wilwood kit. I am running qa1 tubular upper control arms. I want to run the widest tire all the way around so if I can do a 245 on all tires I will. The other issue I'm going to run in the the center bore size that wilwood kit is. It has a 82.3mm center bore size I've notice most wheels are around the 72ish center bore size.
If you step up to a 17" rim, you can run as much as about 5.6" of backspace, the rim clears the UCA (with a low profile zerk on the upper ball joint). Most rims start to interfere with the outer tie rod around 5.6" or 5.7" of backspace if you're using 73+ disks as the reference. Some can run a little more, but not most. 5.6" of backspace lets you run an 8" wide rim with ease, and you can run 245/45/17's or even 255/45/17's without issue or interference.
If you go to an 18" rim, you clear the outer tie rod. An 8" rim can have as much as 6.3" of backspace, again using the 73+ disks as the reference. A 9" rim will now fit up front, usually with the best fit around 6" to 6.2" of backspace. You do have to watch the UCA as full lock with that wide of a rim, tubular UCA's come in handy to run an 18x9 or 18x9.5. But now you can run 275/35/18's in the front, like I do on my Duster.
These numbers are wrong too. A 7" wheel with 4.5" of backspacing has an offset of +13. An 8" wheel with 5" of backspacing also has an offset of +13. Backspace and offset are not measured from the same places.
Where did I say he should run more than 4.75" b/s on the front? I said 4.50" b/s with any diameter wheel. How is that "not accurate whatsoever"? On a stock Dart (which one could have only assumed he had based on the OP info) that much b/s will normally cause the tires to hit the frame rails at full lock. Trying to make it simple for the guy... He did not originally mention any suspension modifications, nor did he mention any desire to run
anything larger than a 17" wheel. Now that you have a lot more info on the OP's car, now I'm "not accurate whatsoever" because I posted way before you had all this additional information? Give me a frickin' break!
Yes I blew it on the offsets. Should be +12.7mm. My math sucks when I'm tired.
You didn't say he should run more than 4.75" of backspace on the front. Which is exactly why your information isn't accurate. With a 17" wheel you can run more than 4.75" of backspace, and you SHOULD.
You can run 17x8's, with perfectly stock suspension, with a 5.25" backspace and 245/45/17's and not hit anything. Not the frame, not the fender, nothing. You can't run that much backspace with a 14 or 15" rim because your rim will hit the UCA. So, when you said this
your information was in fact inaccurate. The OP's first post said he wanted to run 17's, which will let you run as much as 5.6" of backspace, even with the stock suspension. You can't do that with a 14 or a 15" rim.
Also dont forget if your shooting for 4.5 bs on the rear and find wheels with 5.5 bs you can use a one inch spacer to get the bs you want.
Heres the wheels I'm looking at. They are 17x8 with 4.5" backspacing will these work for both front and back.
The only way they'll work in the front is if you run a 225. Any wider than that and they'll rub on the fenders.
To run a 17x8 on the front and make it worthwhile you really need to have at least 5" of backspace. Any less than that and your tire width is limited to the point that you don't need an 8" wide rim anyway.
In the back they'll probably limit you to a 235. Those are BBP wheels so I assume you're converting. What axle do you have in the back? 8 3/4?
