Hello, I have a '70 Dart, with 225-ci 6-cylinder, and TorqueFlite auto trans. (A904G). I consistently keep having trans. fluid leaks, I have changed gaskets numerous times, event the pan itself (bought new from YearOne). I have checked the torque on the nuts, all well.
I have tried both "cork" gaskets and the "black" gaskets, and it still leaks, not much, but just enough to be annoying. Any suggestions?
I am sure the trans. is not overfilled either way.
I am using Valvoline Dexron III/Mercon fluid.
