twotone68
lifetime mopar man
To all you ignition and electrical gurus. My 68 dart 2 dr. sedan. When i put my mancini racing ,electronic ignition conversion kit in. I followed all the instructions to the letter !!! checked all voltages, oms. and soldered and shrink sleeved all connections. The motor is a 75 318, new stock correct for the motor coil, msd super conductor wires. when I first got it running back in July,it ran for about 15 miles and break in time, then the orange control box went out. Ommed the coil and found it to be out of spec. Installed new factory electronic ignition coil and a new orange box. It just lost the control box again this morning. Put a parts store one on it and it's running again. so 5 months later ,why another control box?? Got wiring instructions and my factory wiring diagram out and traced everything. No errors??? any help!!! Also it has a voltmaster high amp. single wire alternater,also wired correctly .
