Headintheclouds
I'm replacing a Torqueflite 727 behind a 318 Poly with a 42RH. As far as I can see the earlier transmission uses 5/16" lines and the later 3/8". I'm not sure about transmission cooler capacity to dissipate heat but would be grateful if anyone has any info.
I'm a bit puzzled by the seeming need to shift more heat. The overdrive unit with lockup should improve miles to the gallon by about 25% and this suggests my 42RH shouldn't need as big a cooler as the 727. Should I stick with the lines and cooler I already have or do I need to go large?
