I am just gonna add.........ANOTHER overheating problem involving electric fans.........
Horse, water, drink. You know.
Just caint tell um nuthin.
1). You have a LOT of radiator space blocked off from incoming air.
2). Throw the stupid 160* thermostat in the ditch and use either a 180* or a 195*.
A Thermostat has ZERO ZERO ZERO ZERO to do with maximum operating temperature. ZERO. It only controls the minimum operating temperature. PERIOD.
3). What's the specs on those fans? You need about 4K CFM of air flow give or take for a warmed up or hot engine.
4). Get your timing sorted out. Didn't you say in your other thread that your timing is at 12* BTDC? That sounds a little low and low initial timing can and WILL cause one to overheat.
5). There have been enough threads on here about bad luck with Champion radiators, that I will never, ever buy one. Were they the last radiator on earth, I would walk.
Thanks for the fan & shroud pix. I agree with the above 100%. The shroud is so tight to the rad surface that it is simply blocking the airflow from all parts of the rad except the 2 holes right in front of the fans. This has been reported and discussed before.That fan shroud is way too close to the radiator. You're asking the air during free flow to make an extremely abrupt turn once it passes through the rad. I'm betting you're getting "stacking" and no air is flowing.
What's the application of the fan shroud?Thanks for the fan & shroud pix. I agree with the above 100%. The shroud is so tight to the rad surface that it is simply blocking the airflow from all parts of the rad except the 2 holes right in front of the fans. This has been reported and discussed before.
Changing to a 180 t'stat wil just move the start temp of the slow temp climb at a higher point, so will not fix the overall temp issue. (Best power and operating temp is a separate question form the current problem.) Change to the big fan, and I bet it will be much better at any road speed. A shroud will eventually be needed to help at low speed and at a stop.
Here is our 3" thick x 22" wide AL rad with a big fan in a 10:1 CR 340; temps have not gotten over 190-200F yet (but were are not in summer yet). The shroud is a Mopar PN adapted on. Look at the depth it has for the air to turn.
Wish I could put in a clutch fan but the space is not there.
