correct flex plate for 360 Magnum
Abodysrule
California
I believe I read on this board that I can use the B&M 10239 flex plate for the 360 Magnum (with A904). My engine builder says no, I must to a Magnum flex plate. True?
Brian
NVRMIND, I reread the post and it says i can use the B&M flexplate only if I get a specially balanced magnum torque converter...I'll just get the magnum flex plate and fit it as described with a rat tail file.
If you're going to retain the Magnum fuel injection, you need to use the factory 5.9 Magnum flex plate anyway. Rat one hole out and you'll be good.
:thumbsup:
Even though you already answered your own question, I'll chime in. The Magnum flex plate is definitely what you want the 10239 is for LA 360.
Cley
Cley
Yeah, as I said, I need to read more carefully...it'll save time (and money).
