[FOR SALE] Crane SMALL BLOCK 15006 Camshaft 284dur 480lift
mgoblue9798
atlanta
$105 paypal ok if you pay the fees
Brand new cam in the box
Brand:Crane Cams
Manufacturer's Part Number:15006
Part Type:Camshafts
Product Line:Crane Hydraulic Flat Tappet Camshafts
Summit Racing Part Number:CRN-15006
UPC:021174019490
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:3,000-6,200
Intake Duration at 050 inch Lift:228
Exhaust Duration at 050 inch Lift:228
Duration at 050 inch Lift:228 int./228 exh.
Advertised Intake Duration:284
Advertised Exhaust Duration:284
Advertised Duration:284 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.480 in.
Valve Lift with Factory Rocker Arm Ratio:0.480 int./0.480 exh.
Lobe Separation (degrees):112
Computer-Controlled Compatible:No
Grind Number:284 H12
