JGC403
The car is my 1976 Duster, going to be replacing the tired 360 that is in it with a high revving 318. Car is a 4 speed, pulled the original 833OD and replaced it with a 833 form a 1968 Barracuda. Manual Steering, Manual Brakes. I'll be lowering the front of the car 1" by turning the Torsion bars down. Stock height rear springs, I figure they will probably sag a little over time.
Plan is to use the car for Auto X and use it on the Street. I would like to run circles around my Dad's 2009 Challenger SRT, lol.
Uni-body:
-K-frame sent to FFI
-Frame connectors
-Front and Rear Torque Boxes
-US Car Tool core support stiffeners
-Maybe J-bars in engine compartment
What I would like to do is, as I add the parts that will stiffen up the chassis; twist the body and see how much each thing on my list does, if any. Cause I don't want to add extra weight that isn't going to do anything for handling.
Rear suspension:
-ESPO springs Rear Leaf Springs 6 Leaf Heavy Duty Stock height (with poly or rubber bushings in front spring eye, suggestions?)
-PST Polygraphite bushings for shackles
-Sway bar
-disc brakes
-FFI Bilstein Shocks
Front Suspension:
-FFI 16:1 manual Steering box
-FFI pitman arm bearing support
-FFI needle bearing idler arm
-FFI tubular upper A-arm
-FFI boxed Lower control Arm
-PST Polygraphite bushings all around, except for Lower control arm will be Rubber
-Adjustable Strut rods from FFI or PST, are they worth it? I need new ones anyways one of the stock ones is bent.
-Bigger Torsion Bars, haven't decided yet, Suggestions?
-Front Sway bar
-11.75 Disc brakes
-C-body tie-rod ends
Will be going to an 18" wheel probably and modern tires.
I think I got everything, suggestions, comments, I'm open to ideas.
Uni-body:
-Frame connectors
Rear suspension:
-Sway bar
-disc brakes
Front Suspension:
-Front Sway bar
-11.75 Disc brakes
