72Duster440
I fired up my car last night for the first time this year, and the volt meter was bouncing between 16 and 18 volts. I put a meter across the battery terminals and confirmed the same voltage. At the end of the season last year, all was fine. I'm going to remove the voltage regulator from the firewall and make sure the mounting locations are clean to ensure a good ground. Is there anything else I can look at?
Its a 72 Duster with a big block, with a 60amp alternator, and a painless wiring full vehicle harness. The harness has been in for 3 or 4 years, and I have never had any issues like this.
