octanejunkie
Mopar Padawan
OK so just to be clear, I am working on several projects, Ford, Chevy and Mopar; I like to be well-rounded in my interests and find playing with the "big 3" very enlightening. That being said, I am doing a GT40 head swap on a 67 Mustang.
The GT40 heads I pulled (casting F3ZE-AA) are 60-63cc Cobra heads off a '96 Ford Exploder, they have pedestal 1.6 ratio rockers (almost identical to dodge magnum heads) and two different tip length valves between INT and EXH, with the EXH valves running roto-caps.
I can replace the EXH valves and get the same installed height of 1.790 on both INT and EXH no problem, and use valve spring shims to set the correct installed height, but the rocker setup is vexing me; the stock ford setup is not adjustable. Looks like the Hughes 1555 is awesome but not specific to Ford. So I either run the stock valvetrain on the 5/16" ford pedestals or drill and tap the stud bosses and install roller rockers. But that is now without issue either.
Roller rockers required guide plates or self aligning rockers. Going with guide plate requires machining of the stud bosses to accommodate the plates, another operation which is not super costly but does add up. I found these Proform rockers already set up for my exact application, not sure if they are adjustable...
Questions to the experienced masses:
1. replace EXH valves or run roto caps?
2. run stock ford pedestal rockers?
3. machine for studs and guide plates?
4. run the proform retro rollers and skip machining stud bosses?
I welcome all advice, suggestions and opinions - even a mild bit of Ford bashing!
