D150 front spring issuse
dirty white boy
50 yr old Juvenal delinquent
stoneville n.c.
not a A body but this is best place for any mopar wisdom ive found! noticed my 80 D150 was leaning on driver front other day. jacked it up and checked it out, broke lf coil spring. ant never seen one them brake before, seen them sag and droop!! wheres best place to get new springs and bump stops?? any thing else i should check/replace while im doing springs??? thanks yall!
When I did my '77, I ordered whatever I needed from RockAuto. Everything got changed/replaced while I was doing the van LCA swap, but I don't remember finding anything that showed wear out of the ordinary.
I had a spring break on my 91 d150. When I installed new ones I got the lower control out of the way by taking out the inner pivot bolt instead of the ball joint and all that. I don’t think I even took the wheels off, but it’s been a while back.
