JamesRR
Gonna change the oil and I am not familiar with the Dana rear ends. Unplug the lower drain? then fill the upper hole til its near the filler hole? Thanks guys. View attachment Dana 60.jpeg
2 quarts for a standard cover and almost three for the Ultimate 60 cover.
I still think I'd run 2 in it (just above the bottom inside of the axle tube.)
2 quarts would put you about right here, and would be plenty.
A lot of people run 1 quart on the strip for less drag.
