1972orangebeast
I have a few parts up for sale that I no longer need and just taking up space.
- Full 2.5 exhaust headers back for 1972 dart pre bent with jegs flowmaster like mufflers, stainless tips, was on the car with stock leaf springs bent for over the axle fit great just went with coil overs $300obo
- Power steering steering box off my 72, worked fine upgraded to rack and pinion $150 obo
- full set of almost perfect ralley rally wheels , center caps, trim rings, good tires, big bolt pattern, tires are white lettered 205/70/14 2 tires have good tread the other 2 are half as much, no dry rot $250 obo
- 2 sets of bolt on 4 piston Summit racing brand, all aluminum, bare aluminum color, bolt on for 72 and earlier spindles, brand new with hawk pads and pre bent brake lines, these are $550 a pair new $300
- Brand New Full disc brake upgrade conversion kit for a body abody dart duster valiant scamp barracuda, this changes over your kframe k member to 73 type spindles, come with single piston calipers, dust shields, spindles, caliper brackets, and new pads, its all new from Right Stuff part number MDC66WKC5 everything there except rotors, kit new is $500 looking to get $250
- brand new set of Russell stainless brake line kit for dodge plymouth chrysler 2 front and 1 rear line New is $75 asking $40
- Fiberglass hemi hood scoop good condition, bolt on style, one corner may need a little work but not cracked all the way through $150
- Hurst like 4 speed shifter good condition not all rusty $75
- 1970 1971 1972 front and rear duster bumpers not bad couple dings, great cores, or possible driver car $50
- Griffin universal radiator, need customer mounts but worked great, 2 row, fit great in my 72 dart $130
- 3 gallon red brand new fuel cell $75
- Wilwood clutch slave and master cylinders $50 for both
- 273 318 340 360 sdjustable rocker arms with push rods, been kept in oil , look great $150
- Holley 670 street avenger carb with spring kit, electric choke, polished, runs great just took it off and went non vacuum secondaries, dont need it any more $250
- rust free 72 plymouth scamp 6 cyl car no motor or trans, tinted windows, great body, no interrior, came from Arkansas $1500
- running 360 will be for sale this winter, it is in my car now you can hear it run and start up, complete motor minus carb, came out of an rv runs great no smoke $800
pm me for more pics located in Buckeye Lake Ohio 43008
