340wedge1971
I have a 73 swinger,How much of a task is it to remove/replace dash pad?Any tips out there?
You'll need to remove the instrument cluster and the glove box liner to access the hardware. There are 5 nuts on studs across the top and a hex head sheet metal screw in each of the turned down ends.
will that instr cluster pull down without unplugging everything?
