darc1722 Well-Known Member Joined May 15, 2011 Messages 158 Reaction score 1 Location Glenview, IL May 10, 2014 #1 Looking for a site that can decode the numbes on a radiator 2949 059 and 59538 under that, let me know thanks!
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,930 Location 92201 May 10, 2014 #2 2949059 is a 69, B body, 26", 318, Auto, A/C Google will get you some sites that have info. Search by rad number 2949059. Unfortunately, most are the same glommed together incomplete listing.
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA May 10, 2014 #3 The five digit code if the vendor number for whoever supplied it to Chrysler. Some of the steel side frames are date coded as well if you want to look for more numbers.
Mrmopartech Well-Known Member Joined Jun 5, 2005 Messages 2,149 Reaction score 90 Location St.Lazare Quebec Canada May 10, 2014 #4 Check out our web site for the rad numbers,mrmopartech http://www.mymopar.com/radiatorspecs.htm
darc1722 Well-Known Member Joined May 15, 2011 Messages 158 Reaction score 1 Location Glenview, IL Nov 7, 2014 #5 Can anyone tell me where I can find the correct fan shroud for a 26" 1969 318, radiator Part # 2949059 ? Thanks
