swing69
fightin' socialism
I bought a Dexter single torsion axle for a utility trailer that I built. I came fully assembled, so I used it off and on locally for the first year that i have the trailer done. no issues.
This year, I'm heading out on a 1000 mile trip, so I decide to pull the hubs and lube the bearings. What did I find? It wasn't terrible, but wasn't good either.
Left side was pretty sparsely lubricated. no bearing wear. But damn; Chinese bearings!!! I expected better.
Right side was again, sparsely lubricated. no bearing wear. Again; Chinese bearings but worst of all, the outer bearing washer was missing. the nut just was bearing up against the inner race of the bearing.
Bottom line? inspect and lube them bearings. and if you have time; change them REAL bearings.
