My 2 slant six '71's both had one.
My '73 California Duster (318) came with a square plastic bottle that had a metal ring around the neck. It was mounted on the right inner fender next to the alternator. Couldn't find a replacement so I went with the one that mounts next to the radiator. The mounting hole were already there for that bottle.
My radiator came from Carolina Radiator, purchased back in the early 80's.Crewchief, you seem to have the same aftermarket radiator than mine : a 26" Spectra
Is it?
I have an OEM restored 26 radiator in a box, waiting for this one to fail then I'll swap it out.
I'm sure in Europe, plus international shipping must be real expensive.Me too. A 1971 #3443970 rad. Incorrect for a slant 6, but it's the only one I could find. Mopar used parts are very very scarce here.
Impressive - this manages to look original in a way I never would have expected a much later part to look.I installed Dorman 603-325 on my 1972 Duster with a correct bracket from whatever Hyundai it is supposed to be from. Bracket bolts nicely to the frame horn and looks like it could be factory for a Duster. Others before me have done this and I copied the excellent idea.
Coolant recovery tanks were standard on Chrysler product beginning in 73 as were many other items, electronic ignition, disc brakes etc..
If you run a recovery tank you also need the proper radiator cap to go with it or it won't work properly.
Great upgrade for your cooling system.
