Differences /6 vs V8 K-Frames
spankster
Martinsville IN
What are the differences between the /6 and V8 K frames for 67-72? I have a slant now and am pulling it and doing v8 swap was going to use the schumaker engine mount adapters. I'm changing over from drums to KH discs, SBP, but want to upgrade to a frontsway bar. My current lower arms have no sway bar tabs, but I have a set of 73 LCA's with tabs. Can I run those 73 LCA's with this 1970 /6 K-frame and upgrade to anti sway setup? From what I've read, the sway bar tabs for the LCA's pre 73 are in different locations, post 73 run through the K-frame and I'll need to upgrade to a spool K-frame. Not sure if I upgrade to a spool I can still run the KH SB discs?
Appreciate Any insight.
