Dipstick won't go back in
This honestly sounds like a really stupid problem to have.
Pull the tube/stick. And inspect the whole thing. Why keep trying to shove it in there when it obviously has some kinda problem?
Problem SOLVED...
I had a couple of friends come over to help with the problem, and the end result to success was to turn the dipstick 180 degrees, insert, give a little twist, and it goes in.
I tried reinstalling in the same way I removed it (finger pull on the right), but if it's on the left, it works.
Many thanks to all those that tried supplying fixes, and even those humorous responses.
Problem SOLVED...
I think someone called that in post #5.... :D
