Distance from centerlink to oil pan
kaharshs
Fall Creek, Oregon
Does anyone have the measurement or can measure for me. I am building a tranny mount and need to know the distance from the stock oilpan of a 360 to the center link of th suspension. I wanna make sure i set it before building the tranny support. My car is 73 duster will slant 6 k-member, 5.9 with la pan, and conversion motor mounts.
Anchor the front engine mounts then level the car and tilt the engine/trans down in rear 2.5*. Then check the carb flange on intake. Should be pretty close to level.
Its not possible to do that to my car because of all the work i have done and current condition of the vehicle mid build. I believe the easiest way would be to know the distance on a stock one. Just out a curiosity what part of the vehicle do you level to use the way you are refering to?
Kyle
Kyle
Level the car by the bottom of the rocker panels.
