OOps. You should put them back. I static time in a case like this. Pull#1 plug, stick your finger in the hole and bump the engine over till compression trys to blow your finger out. Look at the balancer. It should be close to zero on the timing mark. Close enough to get it started again. Pop the distributor cap and the wire the rotor is pointing to is #1. Put your wires on clockwise 18436572 in that order. Always follow up with a timing light to tune properly. Factory timing specs are pretty weak but that's for another thread. I have good luck with 10° before. tmm
