straightlinespeed
Sometimes I pretend to be normal
Sounds like you have a vacuum leak. It should not drop 4-500rpm in gear.
Should be pulling 14-15" or more vaccum at idle and idle at 800-850.
I checked for that all around the engine, I cant find anything. I sprayed carb cleaner all over. My carb is pulling 14-15" at idle.
Like I said when I changed my timing lower (in the teens) it only dropped a couple hundred in gear. Then I wasnt at that 32-38* total timing. Makes me wonder if my dizzy isnt the whole problem?
Another thing Ive been tossing around, what octane gas should I be running with this set up?
