My new 70 Swinger has been a fun one so far. Last night I attempted to install a Pertronix in the original single point distributor. I dropped a screw for the condenser down inside so I needed to take it apart to get it out. Tap the roll pin and the plastic collar breaks in two. No-one has those available. A friend had a distributor and I broke the collar taking it off. The shop he works at had some brass bushing stock that worked perfect. Cut to length and drill a hole for the roll pin. Fixed! It fired right up and I set the timing @ 12° btdc. No ping and quite a bit of zip. I'm liking this!
