DIY Wheel bearing?
There isn't an easy way to flush the axle tubes with the axles in place.
To just remove the cover and clean the sediment from the bottom of the housing plus the fresh gear lube can help.
Check your axles, too, to make sure the bad bearing hasn't caused any pitting or abnormal wear.
