Guy,
Looking to setup a trade deal for a 383 Big Block, but need some help identifying it. Got really screwed over on a 340 deal so I'm a bit over sensitive and want to do my homework this time instead of trusting the seller.
E-mail started with a 1970 Hp engine. It appears there was only the 4 barrel and 2 Barrel option in 1970.
How do I determine that it is the higher compression, better cam (?), 4 barrel engine if the Intake is missing? I'm going to confirm the following with some disassembly.
906 Heads
130 Block (Seems to be the same no matter)
Forged Crankshaft (?)
From the pictures the engine is in rough shape (Lots of surface rust), but the seller is going to pull the head so I can go look and measure the bore.
What is a fair value if it truly is a 1970 4 Barrel engine from a Sport Fury? $500?
906 Heads
