Riddler
Project EH-Body
I'm working on rewiring my 76 Duster with an American Autowire Power Plus 20 kit. I'm fairly certain I have the dome light wiring correct with the door pins. The ground wire from both door pins gets spliced to the ground wire from the headlight switch. Is this correct?
I used this diagram:
What I'm confused on is the light blue wire coming out of the left door switch going to the ignition switch and then coming out of the ignition switch and going to the ignition buzzer. On my column I've located a light blue wire. I'm assuming this is the one that goes to one prong on the left door switch. I cannot however located another light blue wire from the column. Is this wire inside the column with the ignition buzzer?
Thanks,
Riddler
![76ValiantB.jpg](http://www.mymopar.com/downloads/1976/76ValiantB.jpg)
Thanks,
Riddler
