Otateral
The drivers side door latch has had issues since I bought it. When you press button to open the door from the outside, or pull the handle fom the inside then the latch drops on the door. This causes the door to not shut because the latch hits the striker.
The only way to remedy this is to press in the button or pull the inside handle and then grab the latch on the side of the door and push it up.
I don't even know where to begin in fixing this, since I don't even know what's wrong with it. Any help?
