Use whatever you feel is best, but whatever you decide, never mix the glycol based fluids with DOT 5.
Wrong.
DOT 5 does not strip paint like others.
Whatever you do, DO NOT mix DOT 5 with any other.
My DOT 5 conversion has been going strong for almost 10 years.
Just a slight bit of sponginess and a slight bit of additional pedal travel.
That sponginess is your car, not the fluid.
We had a master cyl leak onto firewall and bubbled paint. Went right down and got Dot 5. Added it directly and bled brakes until Dot5(purple) came out. Zero issues 11 years later. Factory disc front, rear drum.
This, like a ****.
Steve, it's not just the internet. It's every single service manual that goes in depth talking about brake fluid differences. That's all I was doing was stating technical fact.
Now, as far as what you said, I agree 100% and that's how I would do it if I ever swapped to DOT5. But I'm not going to recommend someone do it that way.
I've never understood why manufacturers do this.
You're a parts guy, see my post below.
the composition of some seals are not compatible with with the mineral based 5. basically the crux of the issue is that some material is compatible with glycol variants (3,4, 5.1) and some is compatible with the silicone based dot 5, but there isn't a synthetic material that is compatible with both.
there is also the issue that 5 compresses more and has a tendency to "foam" or aerate under repeated heavy load, it is also a gargantuan pain in the *** to bleed, or can be.
i'm guessing that their insistence on 3 or 4 is just to avoid potential problems from somebody that doesn't know what they're doing; or they're unsure of what seals the MC comes with and play it safe with the 3, 4 or 5.1
Compresses more? Yeah, no. Fluids are effectively incompressible, that's kinda part n' parcel to how the hydraulic brake system works.
For everyone in this thread (and all the threads' cousins that nobody ever searches for):
There is ONE major manufacturer that has extensive experience with DOT5, and converting to DOT4: Harley Davidson.
Harley used DOT5 from AT LEAST the mid-70's until the mid 2000's. When they swtiched, I used the opportunity to put this issue to rest.
In Harley world, the -XX part of the part number is the first year the part was introduced, the letter is the revision number.
From the 2010 Harley FXDWG parts manual:
The cover kit, reference number 24, is where the '05 model changed to reference that Harley had switched to DOT4 (the label on the lid changed, hence the new part number).
The rebuild kit, reference number 17, shows 1996 year of introduction (before DOT4 even existed in HD's inventory by a decade)....and there it is, a DOT5 set of seals and cups and everything, spec'd
by a manufacturer in a DOT4 system. The soft parts are compatible with either fluid. At the time, I checked brake hoses, piston seals, and everything.
I've swapped several systems, mixed fluids in a jar on the bench, done everything I could to 'turn seals to mush', 'cause seals to swell', make 'fluids turn to gel', etc. I've never seen it happen. The DOT specs full miscibility, as I cited in other threads on this matter. Run the DOT5, and don't sweat it. Flush n' fill, top off, full rebuild, however you want to do it.
And to put the issue to bed forever....DOT4 has one expected 'benefit' to Harley riders:
Harley-Davidson is recalling 2008-2011 Touring, CVO Touring, and VRSC motorcycles equipped with ABS. Consumer Reports gives the details.
www.consumerreports.org
